what up everybody?
i'm just getting into remixing music videos. a popular genre of music is called "Screw". the pitch & tempo of the track is slowed down & sometimes words &/or phrases are repeated. this is called "Screwed & Chopped".
basically, what i need is someone to point me into the right direction application-wise to achieve this effect w/ music videos.
i've included a Screwed & Chopped version of 50 Cent ft Olivia - Candy Shop[1], so anyone unfamiliar w/ what i am describing can hear a Screwed & Chopped track. this track is Screwed & Chopped by me & it is promo only.
(I hope I'm not violating any rules by posting a promo only file)
thanks for any help in advance.
[1] http://videoreactor.net/videohelp/50_Cent_-_Candy_Shop_(Screwed_&_Chopped)_[Stunna].mp3
http://videoreactor.net/videohelp/50_Cent_-_Candy_Shop_(Screwed_&_Chopped)_[Stunna]_(2).mp3 (chopped a little more)
#1 Stunna
I would use Sound Forge (Sony) to create samples at the pitch and/or tempo that you want (Sound Forge will allow you to adjust these independently), the use Acid Pro to rebuild the track using the new samples. If you want to then do similar to an accompanying video, I would look at Vegas, and specifically the velocity envelopes.
(Apologies to anyone who considers this grave robbing, but I was directed here by the OP following a recent post of theirs)Read my blog here.
thanks for your reply gunsl1nger. I'll give Vegas a whirl since you are the 2nd person to recommend it.
Also, here is an example file[1] of exactly what I am trying to achieve. It is a very popular Rap song from 2005.
I have the normal version also if you need to compare versions, but I think the differences are obvious.
Thanks for your time.
Direct Download:
Note: via RapidShare.de
[1]
ying_yang_twins_-_wait_{screwed_and_chopped}_(radio_edit)_[RamVideosTimka].mpg (55,08 MB)
#1 Stunna
how to extract I (Intra) P (predictive) & B (Bidirect) Frames from video?
By tnwmn in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 22:57 -
How to speed up / Slow down of video - when converting
By DragOnT in forum Video ConversionReplies: 15Last Post: 2nd Jun 2011, 13:00 -
best speed to shoot to get slight slow-motion effect in music video?
By Cumie Music in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2010, 00:58 -
Slowmo & Repeat Edit
By Blå_Mocka in forum EditingReplies: 4Last Post: 14th Jun 2008, 02:31 -
Slow down Video play speed.
By sureshforum in forum EditingReplies: 1Last Post: 1st Feb 2008, 23:51
